Jeff_A_G
- Jan 19, 2005
I know its not a Xbox 360 post, so who knows if anyone will even look at it. Here's my question either way:
Well, I finally had some free time tonite so I figured I'd fire up the old ps2 I found under all the dust from when I cleaned. I plugged in a game, and it didn't recognize one of my memory cards which had all my save for that game. i pull out both and look at them, and the chip part at the end you stick into the system looks a little shorter than the working one. Could this be the problem? If so, what caused that and how do I fix it? If not, what is the problem then?
