ZZJE123
- Dec 25, 2012
- Zach
I have a question about getting a true surround sound signal into my receiver. I currently am using an older Panasonic SA-HT67 reciver, some Dayton Audio and Boston Acoustic speakers. My general setup regarding the computer input is using an external, Creative sound card with a 3.5mm jack to two rca converter. I then have my xbox plugged into my tv (an older Sharp tube TV), including the audio cables in which the sound from the xbox goes into the TV through an RCA connection, then through the TV's audio output (also RCA) into the receiver (which is also RCA). I then thought that this setup was giving me an actual surround sound signal. One day I was fooling around with some multitracks on my computer and tried panning some of the tracks into a 5.1 setup. Through this, and some research afterwards, I found out that a 5.1 signal cannot be sent through a single 3.5mm jack. I did some research on how I could go about getting an external sound card to plug my computer into the receiver. However, all the sound cards either use a digital audio cable, or three 3.5mm outputs. My receiver does not have a digital audio input OR three 3.5mm inputs, only dual RCA inputs, and thus, none of these audio cards would be compatible with the receiver. The only other option I was able to come up with is using an HDMI to RCA converter, some extensions, and plugging that into the receiver. However, my question regarding this is: would using an HDMI to RCA converter send a 5.1 signal to my receiver, assuming the operating system and software are able to do so? Lastly, after finding all of this out, I have become concerned that the setup regarding my TV isn't sending a 5.1 signal either, and that I just psychologically think it is. Does sending audio through RCA the way I do send a 5.1 signal, or am I just "believing" it is? I found it hard to word this the way I wanted to, but this is the best I can do. Any help is appreciated!!
