Ryan_C
- Aug 9, 2000
Hey guys, I have a problem with my car, and I thought someone on here might have encountered it before, or know what to do. It's not major, but annoying.
I have a 2000 Jeep Cherokee, and I have a severe case of the squeaks on my drivers side door. What it SOUNDS like is the weather stripping on the door is rubbing against the weather stripping on the door frame, and thus squeaking occurs. That is the only thing I can figure it is. It only happens while on bumpy roads. I can open my door when it's happening, and the squeaking stops. My door isn't loose on the hinges, I have checked.
I know the dealer won't do anything about it. A friend suggested I put some Armor All or light coating of Vasoline on the weather stripping. Haven't tried that yet though. Anyone have any thoughts or advice?
I know I can turn my stereo up louder , but I would like a more permanent solution. Thanks guys!
