Mark__T
- Feb 9, 2001
Hi
I can't figure this one out.
Here are my components:
A/V receiver: Pioneer VSX-D711
TV: Panasonic PT-40LC12
DVD: Panasonic RP62
HD Digital Cable Box: Motorola DCT5100
When I went to turn on my receiver to listen to FM and turned the volume up. Not only did the FM volume increase, the TV volume also increased?
The TV volume also come through in AUX,CDR/TAPE,VIDEO,CD modes.
The TV volume does not come through in VCR/DVR or DVD/LD or TV/SAT modes.
This is all when the TV is set on Main or Normal mode.
The volume is turned down all the way on the TV.
In Component2 mode TV volume only comes through in AUX mode which is the way it was set up - so no problem there.
In Component1 mode the DVD volume comes through on DVD/LD mode which is no problem. The TV volume comes through in AUX with no TV picture which I guess is no problem and same with FM-only the FM volume comes through.
In RGB mode-which nothing is set to the DVD volumes comes through in DVD/LD mode with no picture and again the same with FM and AUX.
The desired set up was for the TV volume to come out of the TV speakers unless the AV receiver is on and AUX on component2 is set or DVD volume in Component1 and DVD/LD is set.
So I can't figure out why the TV volume is coming through as described above.
Please let me know what you think.
Mark
DVD: Panasonic RP62
Mark
