Andy_Bu
- Jun 2, 2002
Hi,
I have a powered SUB-250 from SWAN.
The sub-woofer has two different inputs it supports as described below
1) Input one is from the "Pre-Amp" and contains two jacks (RCA type) labeled Left and Right
2) Input two is from the "AMP" and contains two jacks (banana/speaker type) labeled High and Level
My receiver is a HK7200
It contains one output labeled for the subwoofer.
The output is only one jack (RCA type) and is described as follows:
Subwoofer Output - Connect this output to the line level input of a powered subwoofer. If an external sub woofer amplifier is used, connect this jack to the subwoofer amplifier input
What is throwing me off is that the subwoofer contains two jacks for each input and the receiver only contains one jack for the output. I don't know how to connect?
Any help would be appreciated.
Thank you
Andy
Thank you
Andy
