JasonMilch
Grip
- Jan 21, 2004
The wife and I just bought a new codo here in Chicago that we move into next month. It's typical of the big city condo where space is at a premium and this poses a problem for my HT setup. The room is a combo Living/Dining Room and my wife has insisted that certain furniture go in certain places. The room is wired for 5.1 but I don't think the speaker plates are ideally located for my use. See diagram below... wall plates are marked in red
My questions are:
Will this setup work for my non-audiophile ears (still want a decent setup though. If not, how would you fix it (aside from moving the dining room table which must stay put. I'm not an electrician so a ton of rewiring in walls is not an option.
I need new speakers so can you give advice on the types (floorstanding, bookshelf, satellite...) that will work best? Not looking for brand suggestions here, just types.
Thanks so much... J
My questions are:
Thanks so much... J
