Chris Eriksen
- Aug 10, 1999
Hello Everyone,
I am in the process of planning a new sub, and I would like to ask for your help with the design. I have built many subs in the past, but the majority of them were for the car audio environment, which presents a completely different set of design criteria. As a result, I am confident in my abilities to build any type of enclosure, but my design skills may need some tweaking.
I will be using a driver with the following T-S parameters:
Vas ----- 235 L
Qes ----- 0.476
Qms ---- 8.086
Qts ----- 0.450
Fs ------ 24.7 Hz
Xmax--- 25.0 mm (linear, one-way)
Mms --- 197.9 g
Sd ------ 890 cm^2
Re ------ 6.8 ohms
Le ------ 1.58 mH @ 1 kHz
BL ------ 10.47 TM
P ------- 500 rms
The sub will be located at the front of the listening area, in the corner. The room dimensions are approximately 27'x14'x12' (LxWxH), and there is one opening on a side wall to an adjacent room. Power is not a problem, as I can feed the sub in excess of 900 watts if necessary. I would like to keep the enclosure size below 7 cubic feet, with smaller sizes being prefereble.
This sub will be used almost exclusively for HT. I am aiming for a sound that is dynamic with good deep bass extension and reasonable transient response. High SPL's are not a major concern - I have a feeling that any design with this driver will be more than enough for my needs.
I will be using a Behringer Feedback Destroyer to tame the room resonances, and if necessary, I can use a Rane AC-22 crossover, which includes an adjustable 0-2 ms delay circuit.
At this point, I am considering a sealed enclosure with a volume around 5.5 cubic feet. Any other suggestions or recommendations would be greatly appreciated.
Thank you in advance,
Chris
Vas ----- 235 L
Qes ----- 0.476
Qms ---- 8.086
Qts ----- 0.450
Fs ------ 24.7 Hz
Mms --- 197.9 g
Sd ------ 890 cm^2
Re ------ 6.8 ohms
BL ------ 10.47 TM
P ------- 500 rms
Chris
