Chris Shelly
- Dec 16, 2001
I am about to make a buying decision. I have my choices narrowed down to 2 models. The Pioneer VSX-D811S and the Panasonic SA-HE200S. The Pioneer is highly rated on this forum. It is also cheaper then the Panasonic. As far as usable features they have about the same amount. The Panasonic has a more robust amp section then the Pioneer. I listened to both at Circuit City and I thought the Panasonic had a little more life then the Pioneer. The Pioneer does have DTS-ES Discrete whereas the Panasonic does not as far as I can tell. The salesman suggested the 811S for the simple fact that it had DTS-ES discrete. Both are available in silver..LOL
Interestingly I noticed that many retailers that don't normally carry Pioneer products actually stock the 811S. It must be a classic.
I slightly prefer the Panasonic because of the better amplifier section but the DTS-ES discrete sounds like an important feature. I can't make up my mind.
I might just forget about both of these receivers and find one with a more robust amplifier and DTS-ES discrete. Of coarse that would cost more.
Is DTS-ES Discrete anything to get excited about? Do all DTS-ES receivers offer Discrete and only Pioneer makes a big deal out of it? I am so confused!!!
Chris
Chris
