Pioneer PDP with external media box (1 Viewer)
bigstufff
James
I have a 50" Pioneer Plasma with the external media box - i would now like to mount this TV on the wall and locate the media box away from the TV. The lead that connects the media box to the TV (white and black - DVI and ???) is only 2m long.
Do i have any options with extending this cable or do I need to contact Pioneer about getting a long cable for big $$$?
tedi055
Evelina Sanchez
Actually you have two choices on this one. This cable is available at any local radio shack.
I believe they have 3m and 6m long. If not then you should be able to get an extension module and get another cable to make you original cable reach the desired length.
foster2292
