Venu Potluri
- Aug 20, 2002
I am looking to buy my first Big screen TV (Rear-Projection). I have read a lot of reviews, went to a bunch of stores to look at lots of TVs and narrowed my choice to Pioneer Elite and Mitsubishi. I am looking for a 65” set. I still don’t know if I want a TV with HD Tuner built-in or not. I live near New York and I suppose I will get some HDTV programming. But my family doesn’t watch much in terms of the evening programming. We are more into Sports, Food TV, DIY, HGTV, etc. So, HDTV programming may not matter for us.
1. Mitsubishi 65” is much larger in size than Pioneer Elite 65”.
2. I wasn’t 100% sure which of these two offered better picture. I thought in one store the Pioneer Elite was winner and in some others, the Mitsubishi.
3. I am waiting for the Mitsubishi WS-65711 to be in stores so I can check it out and compare with Pioneer Elite PRO-720HD.
4. Even though I can afford either one, I prefer one that is easier to set up and control.
5. I will buy a ReplayTV and will record much of the programming I want to watch.
6. I have satellite TV with Dish Network.
7. I have installed wiring for in-wall speakers and will eventually hook up the TV to these speakers, via a receiver.
My dilemma is which of these two to buy? Mitsubishi advertises their Net Command and that is something I can use. They also promise their TV to be upgradeable. Pioneer doesn’t offer either of these two.
Does Pioneer have plans to replace the current models with newer ones as Mitsubishi is doing?
Which one should I consider buying? Thanks.
