KevinCK
- Nov 20, 2001
I'm trying to setup my first home theater at the moment. I have a JVC D-series 32" tv with component imputs. That's it so far. I'm researching the DVD player and receiver at the moment but right now i have a speaker questions.
I'm pretty set on Paradigm (since i'm also in canada). The problem is that i'm in an apartment and don't want to annoy my neighbours too much. So i planned on setting up without a subwoofer for now and adding one in later when i move to more secluded residence. I thought getting towers for the front would help compensate for this.
My first thought was Monitor 7's up front, Mini monitors in back, CC370(whichever is the matchign one) for the center. No sub for now. Would that give reasonable enough bass for both music and a home theater enthusiast or should i be thinking of some sort of sub regardless of how it's going to annoy those underneath me?
However depending on how christmas goes i might need to rethink that budget. Then i would end up with Titans up front, CC170 center, and atoms in the rear. If i go with the cheaper package, do you think this would be acceptable?
Yes i plan on going to listen to these setups but i just wondered if anyone else had suggestions on what to do if a subwoofer was not going to be included in the purchase.
Any help appreciated. Thanks
Kevin
Kevin
