panasonic rp91 PQ vs JVC progressive? (1 Viewer)
Sean Patrick
i was wondering if anyone had done a head-to-head comparison of the progressive scan picture qualiity of the panasonic rp91 vs. the jvc's.
i know the de-interlacer on the rp91 isn't as good as it could be, i am asking primarily about progressive.
Andrew_Ballew
I assume you are asking about the picture quality of each unit when the progressive scan function is working properly. Having seen them both, I would say that the two are comparable, with a slight edge to the RP-91. Both of the units have chipsets, though, that struggle with difficult material.
Andrew B.
Similar Threads
  • 32
  • Forum statistics
    JoeyT66
