Steve Young
- Feb 16, 1999
- Steve Young
I am thinking of getting this unit for a couple of reasons. The first is that I have a ground loop hum ever since I added 2 amps to my system (Carver AV705X and Samson S700). The hum is definitley comming from my 2 satellite systems, since if I disconnect the coax comming in from the dishes the hum is completely gone. So I am hoping this will get rid of the hum and I can get rid of the cheater plug.
The second reason is so I can have my amps switch on/off with the receiver using a 12v adapter plugged into my Yamaha receivers switched outlet and plugged into the Panamax unit. I am wondering if I have the 2 amps plugged into the High Current outputs if they come on at the same time if they will draw too much current? I have tested them currently by turning them on at the same time (they are on the same circuit) and it seems ok.
If any owners of the 5300 or anyone else can give me some more info on this I would appreciate it.
Steve
Steve
