ATimson
- Sep 16, 2008
- Andrew Timson
I'm a recent Blu-Ray convert, living in North America, and looking to expand my collection (especially since I've been holding off on SD purchases waiting for someone to win the format war). However, before I delve into buying various BBC shows (well, okay, Torchwood) on HD, I had some questions I was hoping someone could answer.
As I understand it, most Blu-Ray discs are authored in 1080/24p. However, shows on BBC HD like Torchwood are shot digitally in 1080/25p and mastered for airing at 1080/50i (for smoother scrolling of credits, etc.). What frame rate are these at on the final discs? My understanding is that the spec allows for 1080/50i, but do they do that or will they framerate-convert it? (Or worse, slow it down?)
The manual for my Blu-Ray player says that it's Region A, and that "PAL discs will not play". But a 1080/50i disc isn't PAL, not really. Is my player, a Samsung BD-P1500, going to be able to play a disc that has 1080/50i material? I know that my HDTV will probably barf on it, but I could hook it up to my computer monitor via DVI.
Also, how heavily has region coding come into play? I know that back when Blu-Ray was first introduced, it wasn't often used (because HD-DVD wasn't region-coded) but has that changed recently?
Thanks for any advice or insight you can provide!
