Daniel K
Grip
- May 25, 2006
- Daniel Koll
I just got an Onkyo TX-SR703. My sub is a velodyne CT-120. I made my own cable using RG6 with compression type RCA ends then a y adapter at the sub inputs. The run is probably around 25'. I noticed that the volume of the sub is not loud at all, I can't even get it to reach excursion limits unless the receiver is at insane levels. I checked all the receiver settings including...
Subwoofer...Yes
LFE...Dolby (highest level)
EQ...80hz (highest level)
Bass...(highest level)
On the back of the subwoofer I have the volume all the way up. Why is the sub so quiet? Is it because the cable is 75ohm and I am getting voltage drop from that resistance? Is there anything I can do so I don't have to keep everything at the highest level? Thanks
Subwoofer...Yes
