Jonathan Lofgren
- Jul 10, 2001
In another thread it seemed to be the majority opinion that instead if an HTB I should just spend the money for a pair of better speakers. OK, what should I get? I'm still just thinking, but the HTB was about $400 so I'm looking for something that much or less. I would then just use an old receiver I have until I had enough money to get a 5.1 receiver and add some speakers. I'm not too worried about deep base as I'm sure I will get a subwoofer to help that. It seems that if I spend enough time here I may end up with several. I've been looking at these:
http://www.norh.com/products/norh4/index.html
http://axiomaudio.com/1M22.html
I thought this http://www.audioreview.com/audio101/diyspeaker/
might be fun to try, and the reviews have been good.
The only other company I've been looking at is Paradigm, but I'm not sure which of their speakers would fit in my price range. Also, I could get two pairs of Axiom M3's or Paradigm Titans or something for the same $400. Would that be a better use of my money?( Keep in mind that I live in northern Minnesota and can go to Canada to get a better deal on the Paradigms or Axioms.) Again, any help is greatly appreciated. Thanks
[Edited last by Jonathan Lofgren on September 17, 2001 at 11:32 PM]
