Mike_Heggemann
- Mar 25, 2003
Hey all,
I just recently made "the plunge" and got into this HD world.
I just recently picked up a 37" Westinghouse LTV-37w2 HDTV and a Playstation 3.
When I picked up the HDTV at Bestbuy, I was told it had 2 HDMI ports, but it didn't - it only had 1. But, after hooking up my Sony DVP-NC85H upconverting 5 DVD changer to it (via HDMI) and seeing how beautiful the picture was, I didn't feel like taking the TV back to exchange it for the similar Insignia model that had 2 HDMI ports on it. So, I had to hook the PS3 up via component cables.
Now, here are my questions:
1) I know that the PS3 does not upconvert SD DVDs via component (it outputs it at 480p, which kinda makes the Widescreen HDTV a moot point unless I tell the TV to "fill" the picture), but will it play Bluray discs in HD over component (my TV supports both 720p and 1080i)?
2) The HDTV works great and looks beautiful except for one thing: it seems to not like one of my over the air HD stations (I don't have cable or satellite) - the TV has locked up (the screen will freeze and audio will stop) twice on this station, and this station only. I have to power down the TV and then power it back up to get control back. Signal strength is one bar from maximum, so it doesn't seem to be a signal strength issue. Is it a problem with the TV itself, a firmware issue, or just something that can happen occasionally in this brave new HD world?
3) I'm somewhat confused by this upconvert thing, but I think this is the upshot: if a DVD player does not do upconversion, it will output to an HDTV in 480p, which means it won't be true "widescreen" unless either: the HDTV does upconversion, or you have the HDTV "fill" the screen. have I got this right?
4) Anyone want to soothe me by telling me I was right to keep Westinghouse over going back and trying the Insignia to get the extra HDMI port? (Based on price and features, these were my only 2 options)
