New Rocket Subwoofer (1 Viewer)
Chris Bone
Does anyone have any performance specs on the new Rocket Subwoofer? How does the 10" driver compare to a SVS 12"? How do you think two Rocket Subs stacked would compare to one SVS PB2?
Curious,
Chris
Lew Crippen
The UFW-10 is in beta as we speak (or write). It is sealed with (as you note) a 10”driver. The unit contains a 325 watt digital amp and a parametric equalizer. According to some informal reports from a an AV123 demonstration in Chicago, Mark said that it would hit 97db at 20hz.
If you can wait, there is a 12” model with a 750 watt, programmable amp up next.
We will know more as the beta testers make their comparisons. At least one of the testers owns SVS, so there should be some objective data.
I’ve got one on order already.
Mindy
