Drew_Whitehead
- Dec 8, 2015
- Drew
So I'm cutting the cable cord. The mound of problems I run into revolves around the fact that my TV is incapable of turning off its internal speakers. Toshiba 55g310U, I've tried everything, been on their support and done everything short of open it up to cut the speaker wire. Those internal speakers won't fill my living room, thus the sound bar via the only out from the tv, the optical out. Now control volume on the sound bar alone, I have a square of electrical tape covering the eye on the tv. All well and good given the roku and blue ray are hdmi into the tv. When I added a converter box, because I can't use the built in the tv because of the electrical tape, it wants to adjust it's own volume on its own.
Long story short, anyone have a simple solution other than replace to tv or a receiver? Quality TV tuner box that doesn't want to adjust it's own volume? Thanks in advance.
