Curt Badry
- Jan 5, 2004
This is my first post. Hat's off to everyone envolved here,(members/admins) that make this forum work.
Ok, I need a little clarification. I have a Yamaha RX- V 495 reciever.It had DD 5.1 but does not decode DTS. Yesterday i went out and bought a new Panasonic S-55 DVD player because i read that it decoded DTS. The manual is not very clear on exact connections/settings, that's where i need help.
The way i have it setup now is, I have my DVD player connected to my reciever with an optical cable. In the settings for the DVD player it tells me to set DD to bitstream if my reciever can decode it, which i did. For DTS it tells me to set it to PCM if my reciever cannot decode it, which it can't. With the settings the way they are, am i going to be successful in recieving the Dts signal, and will it sound better than DD 5.1? I ask because i am under the assumption that bitstream is digital and PCM is analog(i'm probably wrong). So will Dts movies sound better being played in DTS,set at PCM going through my optical cable, or should i watch them in DD 5.1 set at Bitstream through my optical cable?.
Another thing, on the back of my DVD player, there are analog conections for 5.1,sourround,sub,center. I have nothing hooked up to these, as my reciever decodes 5.1 and i have all my speakers connected directly to my reciever. I originally thought that the only way that my DVD player would decode DTS was if my speakers were connected to the DVD player itself. I hope i have it hooked up correctly, i have never experienced DTS before, so i hope i am able to achieve it with my current config.
Sorry for the long post, but i wanted to be as clear as possible when asking for help.
Thanks in advance
Curt
Thanks in advance
Curt
