John B.
- May 19, 1999
Level 4: CIA Headquarters....
At the spot towards the end of the level where you come out of the building in the rain to the rendevouz point, and there are stairs leading down (to 1 level still above ground level) and farther down you can see a truck waiting...
How do you kill the one guard patroling around the stairs below without sounding any alarms?? I have all savepts on the same spot where if i get another alarm it's over.
