Chris Rein
- Apr 18, 2000
Hello,
I've done some extensive searches the past few days, and I've decided to make my own speaker cables/wires. I plan on getting either a 100' spool of Sound King 12 gauge wire or a 100' spool of Liberty Wire 12 gauge.
Now, what I would like to do is put a "nylon braid" over the outer part of the wire to give it a nice finished look. Any ideas on where to get the braid? And, if so, what's the part numbers I should be looking at?
One last thing, I'm either going to finish them with banana plugs or spades. After the nylon braid, what type of heat shrink could I use to put over the white wires, and what's the best way to go about doing that.
Sorry for all the questions. I think this would be a cool/fun DIY. Thanks for your help!
Chris
Chris
