i think it may be asking you to plug in, for every value of x in f(x), g(x). im not sure though, confused by how it is written. but if that is the case, you have (f/g)(x)=[(2x-4)^2]-1. just pretend that g(x), also 2x-4, is x in the f(x) equation, and plug it in, as i did above. you may be asking for something else entirely though
This is f divided by g. There is nothing else to do other than what you already wrote, x^2-1/2x-4, unless you want to attempt long division. I don't see why though.
Sorry, but this is a calculus question. It is not as simple as dividing the top by the bottom. It could be a case of substituting g(x) into f(x), but it could also be question that uses f' and g'.
like f/g(x)= f(g'(x)) + f'(g(x)/g(x)^2
I'm not sure if that equation is totally correct. I don't have my calculus text available, and even though I took the course I didn't do too well. I would actually have to look it up and see if it correlates.
Ah, yes, I vaguely remember now. You might be correct. It could be a substitution problem too, though. Damn, I wish I had my text book and notes here. Now it is going to bother me. I agree with your other comment though.......DYOFHW.
Edit: I should add, wouldn't that require a limit to be implied? God....I can't believe I only took this stuff a little while ago and I'm already having trouble remembering how it went.
Its not hard.......you just divide what I gave you the first time and that is our answer. It is SO easy and all you all are just making it much more harder than it needs to be.
The college math lecturer (me) should probably step in here. Edwin, the rule you were thinking of is the quotient rule for derivatives. It allows you find the derivative of a function that has the form f(x)/g(x), where the / stands for division (as it usually does). That rule can be expressed this way:
[f(x)/g(x)]' = [f'(x)g(x) - f(x)g'(x)]/g(x)^2
However, the original question:
does not appear to involve taking any derivatives. It's most likely just looking for f(x) divided by g(x). A similar notation can be used for other ways of combining functions:
Look I did four out of five of the same problems just like this! So far NO ONE has helped me. I could've reiterated the babble that has come out of everyones mouths so far. Please help me divide that or dont post anything.
Yes. Thank you, Haggai. I finally decided to use this wonderful thing called the internet and actually look up the notation and see if I was making a complete hash of it. Sure enough I was.
I have always wanted to pass calculus and have yet to do so. I've taken the bloody 1st year course twice, but I just can't seem to get my head around it. With your explanation some of it started to come back a bit.
