JasonKrol
- Aug 19, 2001
Hey all,
I dont know if this is the correct forum to post this, but you seem the most knowledgable. I just got the Toshiba 50H81 widescreen RPTV the other day and its just extremely awesome. I have 2 questions though. First, it has multiple view modes to force regular tv to widescreen, TheaterWide1, 2, 3, and Full. Im wondering if Full is the mode that I should watch regular DVDS in?
Second: I noticed (mainly because im very anal) that when watching 2.35:1 DVDs, or any DVDs with bars at the top and bottom, it almost seems that the picture is taller on the right side than the left. Here is an extremely exagerated example of what i mean:
Now again, that is extremely exagerated, its difficult to explain using text, and the actual problem is very slight. Any ideas on how this might be fixed. It almost seems like you need the Trapezoid function that most monitors have that you can adjust the height of each side of the pic. Are there tools that technitians use to fix this slight problem? Im wondering because if so, I will call the place I bought from and see if they can send a tech out to fix it.
Thanks a lot for listening and any advice!!
- Jason
My DVD Collection | My Home Theater
"what ya got here is two people dragging a third..."
- Jason
