Hi everyone
I need some help with the purchase of a DVD.
Right now I own a Pioneer Elite DV-09 and I am thinking of buying a OPPO OPDV 971H.
Do you think I will get a better picture and sound. I 'll
tell you about my DV-09 for those who are not familiar with it because of it's age.
THX Certified
*Urushi w/ Rosewood Finish
Mechanical Features
*All Copper Chassis & Internal Shielding
*Aluminum Front Panel
*Quad Layer Chassis
*3 Box 4 Chamber Construction
*Double Air-Lock Shield Door
Performance Features
*New Video LSI for improved data reading and improved Video S/N ratio
*Exclusive Video Processing Circuitry
*Component Frame DNR
*Y/C Timing Adjuster
*10 Bit Video Encoder
*DTS Compatible
*Twin Non-Switching Power Transformers
*New Accurate Digital Servo for reduced Jitter
*10 Bit Video Processing
*10 Bit Video DAC’s
*High-Bit Legato Link Conversion S
*Dual 96K / 24Bit Audio DAC’s
Convenience Features
*Jog / Shuttle Remote
*New GUI Menu System
*Heads Up Full function remote
*Bit Rate Display
*Condition Memory
Output Terminals
*Component Video Output (DVD only)
*AC-3 Bit Stream / PCM Optical Output
*Gold Plated AC-3 Bit Stream / PCM Coaxial Output
*Gold Plated PCM Coaxial Output
*Gold Plated Analog Audio Output x 2
*Gold Plated S 2 Video Output x 2
*Gold Plated Composite Video Output x 2
*Net weight 40 lbs.
Slate
THX Certified
Mechanical Features
*Quad Layer Chassis
*DTS Compatible
*10 Bit Video DAC’s
*Bit Rate Display
*Condition Memory
Output Terminals
*Net weight 40 lbs.
Slate
