Stacey_V
- Mar 2, 2000
First off, it's fair to say that wood, saws, pencils, and tape measures are NOT my best friends.
I have finished my new Cedar deck, and now I need to put stairs down to the ground. Does anybody know the correct way of figuring out how many stairs will be required? I know that rise/run comes into play somehow, but the logic escapes me. I don't want to start cutting and then find out that I have miscalculated things.
This is what I have:
1 x 10' 2x10 for risers
4 x 8' 2x6 for stairs
I want to be able to get both risers to be cut from the one 2x10. The deck is only about 34" from ground level, so hopefully this one board should do both.
I want the stairs to be 2 wide for each step down. Imagine the 2x6's side by side on one riser.
I hope that I have given enough info for somebody to provide the proper way to go about doing this. I don't need the correct measurements to cut etc. I can do that if someone can at least provide the proper way of figuring out the rise, run, etc.
Help!!
Stacey
Help!!
Stacey
