Jack Ferry
- Oct 20, 2003
- Jack Ferry
When all the little kiddies in the neighborhood come looking for free candy next week, I thought I'd try something a bit different: I want to set up my InFocus 4805 for outside viewing. While I'll probably set it up as simply as possible (projecting on a wall), my alternate idea is to put material across the garage door opening and rear project from the controlled environment of the garage. (Since rain and electronics don't mix well.)
My question: what material works for rear projection? Does clear plastic like saran wrap work? Is there anything I can buy cheaply in a very wide roll?
I'm probably going to show Monsters Inc unless someone has a better idea.
(I wasn't sure if this should be in the construction forum, but I thought I'm more likely to find my fellow front projection nuts here.)
