jack x
- Feb 27, 2002
Need advice on Cables / Interconnects
Hi,
As I am putting together a new system, I need advice on interconnects – since I am starting from scratch and have none. I need interconnects from Rotel 1055 receiver to cd player (might be SACD when the dust settles) VCR (audio cables?) and DVD player (might have 5.1 outputs for DVD-A).
I also need advice for a digital coaxial connection. My understanding is that coaxial is less fragile than toslink, so I would prefer to go with coax..
My TV does not any inputs – just a single coaxial input from antenna.
From what I have read, Monstercable is not the way I want to go. I also heard that if using e.g. AudioQuest interconnects, it is advised to NOT use their low-end offerings. Then, of course, price becomes much more of an issue.
Perhaps my budget is not realistic, but I wanted to stay under $150-200. I especially realize that this might be less realistic if including 5.1 interconnects for DVD-A or SACD. Perhaps a better way to phrase the budget – in terms of cost per pair (1meter or shorter).
Is this something I can purchase based on specification/advice/price, or do I really need to demo cables?
I also need speaker cable, but I think it best to not include that discussion on this heated topic.
Thanks for your suggestions!
jack
Hi,
jack
