Norman Short
- Dec 28, 2001
I read somewhere an article talking about putting the subwoofer very close to or directly behind the listening position as an alternative to conventional corner placement. The writer argued that you don't need nearly as much power to get the same SPL output at the listening position, and your bass would be made up much more of direct rather than reflected waves. It also enabled bass to be better performing for you while saving some calls from irate neighbors. This sounds logical, but corner loading seems to be the prevalent point of view here on the forum. Of course I can try out both for myself, but I was just wondering what if any downsides to such an approach there are, and perhaps there is some flaw the article's author hadn't considered. I realize you would lose the corner loading, but wouldn't proximity make up for that?
Norman Short
Norman Short
