Bill Catherall
- Aug 1, 1997
Well...I finally came up with a design that I like and also has a good SAF. The reason the SAF is higher on this design is because it can hide in the corner behind the couch. We have a sectional that has a curved corner piece. This leaves a sizeable unusable area behind the couch. I was thinking that if I make a subwoofer that fits back there then the wife might not object to it. So here it is:
A front view.
A back view with a side removed so you can see the inside.
You can see all the design specs by http://wcatherall.homestead.com/files/subwoofer/sub.html I'd rather be wrong now than after I spend the money.
Also, I have no idea what the actual dimensions of the flare are so I had to guess. What is the mounting hole size for a 6" flare? I plan on putting a grill over the vent to keep the kids from putting things inside. I know that's where all the toys and even food will go if I didn't.
Bill
A front view.
Bill
