Phil Tomaskovic
- May 8, 1999
I've noticed at times the blue light (multi-channel decoding indicator) will flash on and off occasionally. I was under the impression that if a 5.1 dvd was playing, that light should be on continuously (same as the similar light on the dvd player). I've noticed it flicker during quieter passages, but not consistantly. Is it possible I have a problem with my connection (coax) or is this normal?
