Chris Svencer
- Mar 4, 2002
Can you uninstall MSN Messenger from XP so it doesn't go to the systray everytime you open IE?
Thanks.
-Svence
Thanks.
-Svence
When you install Windows XP Service Pack 1 (SP1), Windows adds a new feature that is named "Set Program Access and Defaults" to the Add or Remove Programs tool in Control Panel. You can use this feature to remove Windows Messenger from the Start menu, the desktop, and other locations. For additional information, click the following article number to view the article in the Microsoft Knowledge Base:A riskier method I guess, but I think I used this to disable it:
Do a start/run and use this command to modify the registry:
rundll32 advpack.dll,LaunchINFSection %WinDir%infmsmsgs.inf,BLC.Remove
