Scott L
- Feb 29, 2000
I'm capturing Conan skits onto my computer and I'm wondering which is the best codec to use. I set the Asus to capture 320x240 mpeg-2, then I convert that to Divx 5 (dual pass @ 1600kbps) and the audio to Lame 192kbs VBR. The result is ok but one thing I've always hated about Divx is when you try to advance through the timeline the whole video stops and if it does come back on again the auido is out of synch.
Any other codec options out there? I've been hearing stuff about Xvid, is that worth a try? Also does 1600kbps sound a tad high for a 320x240 video?
Thanks for any help.
