JackIR
- Nov 27, 2001
I have a set of Monster M350i interconnects between my processor and amp. I was thinking of replacing them with Canare. Is Canare a better cable?
A mistake would be to replace them with an RG6 coax cable with Canare crimp on connectors. While fine for video and digital they are a poor choice for analog audio interconnects.Mark, just curious, but why do you say that RG6 with canare crimp on connectors is a poor choice for analog audio. Not trying to start an argument, just want to know why you say that.
Most of the Monster connectors have a vampire grip on the RCA connector making it difficult to plug & unplug.I hate to play devils.. er.. Monster's Advocate But the tight RCA plugs may be why some people prefer Monster over cheaper cables.
(Here comes my opinion, dont take it as generally accepted)
Subwoofer cables seem to prefer a grip-of-death connector. This might be why Monster cables have them.
Canare is famous for it's high-quality RCA connectors which are an important part of a VIDEO cable. It tries to maintain the 75 ohm impedence which is vital for video. It's not nearly as important for audio.
I love the Canare cables for video applications. But the things that make Canare great for video .. just are not as important for audio. Since you already have Monster cables .. I just dont honestly feel that the Canare cables would give you much improvement for AUDIO.
SUGGESTION: Can your TV take a component video feed and do you have a component video source like a DVD player? If so, measure how long of a component video cable you need, and buy one Canare cable long enough to serve either use. Now you have a great video cable, and you can use it for the front 3 channels for your audio system. This way you can 'audition' the cable for audio and decide for yourself if it's worth it.
Many of the custom cable sites have very good return policies so shop around before you decide where to buy.
