Paradigm Monitor 7 & Denon 3803 Volume
Discussion in 'Speakers' started by JohnSap, Oct 10, 2003.
  1. JohnSap
    JohnSap Auditioning
    Oct 9, 2003
    8
    I just purchased a Denon 3803, Paradigm Monitor 7 fronts, waiting for the OTW-cc370 (on-the-wall center) and ADP-370 (rear). The speakers are great. The Denon 3803 is great. The two together don't produce the volume I would expect. I would never have expected to be able to turn the volume all the way. The speaker cables are just OK 16 gauge monster until the other speakers arrive then prob. Canare star quad cables.
    The source is a Denon 1600 (soon to be upgraded to a Denon 2200) or a HD SA cable box (set to fixed volume). Again all w/ just OK temporary interconnects.
    The Paradigm should be fairly efficient speakers w/ a sensitivity of 93 dB.
    Any advice?
  2. James W. Johnson
    James W. Johnson Screenwriter
    May 26, 2001
    1,055
    You sound like a good candiate for some Klipsch RF7s.
  3. John Garcia
    Jun 24, 1999
    11,571
    24
    NorCal
    I got more than enough kick out of my Monitor 5s, so I would say the first thing you need to check is your setup. There are a dozen possiblities that could be causing this. Does putting the receiver in "pure direct" raise the sound level? If so, this is a setting issue. IMO, you should not be able to turn the volume all the way up.
    Is your room very large?
    What disc(s) are you using to test?
    Do you have digital compression or some other form of attenuation turned on?
    How do you have the source hooked? Analog or digital? If digital, is the source set to PCM or bitstream?
    I'd take the M7s over the Klipschs. I am definitely not a fan of Klipsch.
  4. JohnSap
    JohnSap Auditioning
    Oct 9, 2003
    8
    I have been away for a while but here is the run down. I upgraded my DVD1600 to a DVD2200 and love it. Much better build and layer changes. When I added my new Monitor 7s , I changed the speaker size from small to large for the fronts and center in the 3803. The sub was set to LFE only. So the real problem was no bass from the sub. Changing the sub to LFE + main solved the problem. Or changing all the speakers to small and the sub to LFE + main. I chose the latter and have much better volume.
    That doesn't change the fact that I don't believe the 3803 can deliver 770W (110W x 7) total power. I am happier but still might move the fronts to a separate sometime in the further but for now the AVR3803 + DVD2200 are working fine. Thank Everyone.
