Chris.Gray
- Dec 30, 2003
I have a mits WT model 46” rear projection TV. Component input #1 and the DTV component input have red bleeding through on black images. If I switch to component input #2 there is no red and black is black. It looks great on that input.
In the past I have entered the service menu and copied settings down and transposed them to other inputs that have had the red in black problem, but this time it’s not working.
If I place a 480p signal on the bad input and copy the values from the good input its still bleeding through and there is no change. So my question is there a global place to set the 480p settings? I know I can toggle through NTSC, 480p, HD, VGA on each input. Do changes to theses modes only impact the input that I am currently in?
Also another strange thing happens. When I am on the component #2 (the good looking input) I enter the service menu, select 480p mode and then start toggling through the each setting and I get the reddish bleed in the blacks at certain points. I only get this when I reach about the 12th item to adjust under the service and I toggle through about 3 or so more and it goes away and back to normal looking. I know I most likely have grayscale problem and I am just looking for a Band-Aid for this issue right now.
Thanks!
Thanks!
