avia question--elementary
Discussion in 'Archived Threads 2001-2004' started by Jimmy vb, Aug 28, 2002.
  1. Jimmy vb
    Jimmy vb Stunt Coordinator
    Aug 26, 2002
    54
    I just got a mitsubishi ws55809. The picture out of the box is pretty good but may benefit from a calibration. I could try to find a pro to do it(probably a good idea) but was interested in exploring AVIA or another product.
    The user tuning options with the tv are limited to the basics(brightness, contrast, sharpness, color, tint, a couple of mode choices, etc..along with manual convergence options). My question is, does AVIA work using these user options or do you need to go into the service menu(which I am not comfortable with at this stage--unless it is fairly simple). From the AVIA page I get a list of the different tests and menu options but I don't have a sense of how it works. Could someone who has used it give a basic pointer on how these calibration/tuneup programs work and whether they work off of the user adjustments.
  2. John Royster
    John Royster Screenwriter
    Oct 14, 2001
    1,088
    Jimmy,
    The basic avia tests are sharpness, brightness, contrast, color and tint. Just these user adjustments can have a significant impact on your picture. All you do is follow the narrated instructions for each setting, very easy.
    So, YES...avia can help you adjust these.
    The disk also has dozens of other tests to help with other tweaking.
  3. Michael TLV
    Mar 16, 2000
    2,909
    Calgary, Alberta
    Michael Chen
    Greetings
    There is actually a video segment that walks users through the basics ...
    It is a good disc for both beginner and advanced users.
    Regards
