chris.dillon
- Mar 3, 2002
I am finishing my basement and realized the other day that I was going to have difficulty with tht center channel speaker. I am putting a Plasma above a fireplace with a 7' ceiling. Once the Plasma is on the wall there will not be room for a speaker above or below. So I was looking into ceiling speakers and found the Kef Ci200QT These are ceiling speakers that when needed are motorized and swing down to point toward the listener. It seems like my best option.
I have a couple of questions:
1) Should the front speakers all be the same maker?
2) Should the front speakers all be at the same level?
If not where is it appropriate?
3) It's alright for the surrounds not to match correct?
Thanks for your help.
Chris
Chris
