Racio Martinez
- Apr 27, 2002
Hi all,
I just purchased the above-mentioned receiver and have been tinkering with it for a while. However, I can’t seem to configure my front speakers to run “full range” without cutting-off the audio signal to my sub. The only way to revert back the audio signal to my sub are if I set my front speakers to “small”, or choose “THX” at the top of the menu, which of course would subsequently set the rest of my speakers to “small”. I’ve checked the manual and all, but I can’t find a way around this. :frowning:
If this “peculiarity” with the Marantz SR8200 has previously been tackled and resolved in this forum, then please direct me to the proper thread. I recently upgraded from an SR6200, so I’m quite aware that this is pretty unusual since I had no problem with such setup with the latter receiver. :frowning:
TIA,
Racio
TIA,
Racio
