I plan to purchase a 32" LCD in a few months and I am looking for a mount that moves up and down. I would like the ability to change the height of the screen and not just a tilt function. Thank You.
You might want to hunt around for scissor mounts that are deigned usually to come down out of the ceiling. They might be helpful for you. They had these in CRT days, obviously that's overkill for a small digital, but I'm sure there's probable some kind of similar solution out there for that.
