Tim Knapp
- Feb 18, 2002
I'm considering buying a litom lvd-2001 to try out it's hdtv resolutions on my hdtv compatible mitsubish xd200 projector. I can connect to the projector via component inputs. Will the liton send the hdtv signal through it's component outputs?
Second question: I read that you have to have an HDMI interface to watch copy protected dvds? Are all/most the dvd movies i buy or rent copy protected? If so, where can i find the interface that i would need.
Thank you.
Tim
Thank you.
Tim
