Steven Good
it's a long one. . .
I just picked up a Panasonic DMR-E30K, after dabbling with a PC DVD-R burner a few months ago. It was more involved than I wanted to deal with (not getting satisfactory captures to hard drive, etc.) so I returned the whole mess and waited for the price drop and the new Panasonic model to arrive.
So...I have a Pioneer CLD-702 laserdisc player and want to burn some LD's to DVD-R. Since there seems to be a lot of tweaking of settings to get the best results, I could potentially create a lot of coasters...unless any of you are willing to pass along your secrets of successful use of this machine?
I know that the comb filters, etc. in the Panasonic recorder almost HAVE to be superior to the 702's comb filters (now 10 years old). I'm pretty sure that I should pass the video signal to the recorder with composite cable, because the signal on the LD is mastered (?) that way. I'll be using Monster brand cables for both the video and analog audio 2-ch. to the recorder.
Now, the Panasonic instruction book makes my head hurt. I'll just throw out some settings, and you can respond with an "on" or "off", and perhaps why....
3-D Y/C Seperation --Does this affect recording from all sources, or just the internal tuner?
Hybrid VBR Resolution--"Automatic" (?) I will avoid the 4 and 6-hour crap settings. I may use the 1-hour setting for short programs (like the Roger Rabbit short subject collection, etc.), but mostly the variable setting seems to suit my needs, as the films I want to record are around 2 hours--give or take a few minutes.
The User Select Video Settings:
Picture: Soft, Fine, Cinema, User. Is this for recording, or just playback?
MPEG-DNR: (When any item other than "User" is selected) You can turn on and off the recommended settings for 3D, NR, block NR, and mosquito NR.
When "User" is selected:
Contract -7 to +7
Brightness 0 to +15
Sharpness -6 to +6
Color -7 to + 7
Gamma 0 to +5
3D NR o to +4
Block NR 0 to +3
Mosquito NR 0 to +3
I will be playing these DVD-R's back on a Toshiba SD-4700--the great zoom will help with taking these 4:3 letterbox discs and blowing them up to proper scale (without gray side bars) on on my 65" 16x9 Mitsubishi intergrated HDTV.
And as long as I'm asking for the moon and stars... I will eventually be transfering some VHS and 8mm stuff, as well. For playback, I'll be using a Mitsubishi HSU-795 S-VHS deck, and an RCA 3-head Hi-Fi stereo 8mm deck. I should use the S-video output (instead of composite) for the VHS stuff, right? None of the footage was actually recorded in S-VHS fomat, all VHS. The 8mm deck only has composite out, so no choice there. What settings on the Panasonic recorder should I change to get the best dub of these tapes to DVD-R?
I really appreciate any and all replies. Don't let the televi$ion fool you; I'm a cheap b_______ , and don't want to make any DVD-R coasters if at all possible. Wasted blanks mean fewer $$$ for more A/V stuff!!
Steven
Contract -7 to +7
Brightness 0 to +15
Sharpness -6 to +6
Color -7 to + 7
Gamma 0 to +5
3D NR o to +4
Block NR 0 to +3
Mosquito NR 0 to +3
Steven
