DerekCV
- Feb 21, 2005
I know that the standard is to put your mains on “small” and let your sub do the work… however I get good bass out of my mains (HTD level 3 towers, crossed at 50Hz until I hook up the sub, then I might bring it up higher). Am I going to limit my subs performance by having my mains set to large? I hear that doing that will not always send the signal to the sub… is that the case? Also in my receiver setup it has the option of “yes”, “no” and “plus” under the subwoofer settings… I was confused as to what the plus meant. Anyone have a suggestion?
