Chris Eriksen
- Aug 10, 1999
Hi Everyone,
I hope you can offer advice on my speaker dilemma. For spouse approval reasons, I am limited to in-wall speakers for my rear channels. My mains are a/d/s/ L1290/2's, which are large, floor-standing 3.5-way towers with soft dome mids and tweters. After a lot of listening, I am having a hard time finding anything that is a good sonic match. I have auditioned a ton of in-wall speakers, and the closest match so far is the NHT 6.3 Ci. The current in-walls from a/d/s/ were also similar, but not as close as I would like. (Possibly due to their poly woofers versus my paper cones?)
Recently, I have found a good deal on a pair of a/d/s/ L520's, which are large, sealed-enclosure, two-way bookshelf speakers. Sonically, these are a good match to my mains. I also found a pair of a/d/s/ L1230's, which are large, sealed-enclosure, floor-standing, 3.5-way designs that are a perfect match for my mains. (identical drivers)
I have been playing around with the idea of removing the drivers and mounting them as in-walls. Has anyone tried something similar to this? Since a large sealed enclosure behind the wall is not an option, would aperiodic loading be appropriate? I have built AP subs, but I am unsure of what effect the AP loading would have on the midrange response.
The speakers will be driven off of the rear channels of my Onkyo 696, so they will see around 100 watts per channel. I am almost positive that I would set the L520's to 'small', and I am equally as confident that I would run the L1230's as 'large'. If I use the L520's and a 'small' setting for the rear channels, would it be possible to run them in an infinite baffle configuration? My receiver's high-pass filter is fixed at 80 Hz @ 12 dB/octave.
Any advice that you can offer will be greatly appreciated.
Thank you,
Chris
Thank you,
Chris
