Nick Montgomery
- Jan 29, 2003
I have decided that I am going to get the JBL SCS150SI speaker package. Seems to be the best bang for the buck.
I was wondering if anyone knew if you can position the speakers on the mounts. What I want to do is mount the front speakers on the side of my entertainment unit and face them forward. Will this be possible?
Also.. It appears that the center channel speaker is the same as the rest. It is just turned on its side with a different grille. Is this correct?
--Nick
--Nick
