I view it as "widescreen is anything which, when displayed on a 4x3 set, contains black bars on the top and bottom; there are two types of widescreen: anamorphic, and non-anamorphic; for simplicity's sake, non-anamorphic is refered to as letterbox".
That is how the online DVD community at HTF and other sites has "raised me" to use those terms.
I also prefer the above "meaning" of letterbox(ing/ed), and I think it's strange that The Digital Bits has always used the term "letterboxed" with all widescreen titles, including the anamorphic ones.
Not in a confusing way though.
I view it as "widescreen is anything which, when displayed on a 4x3 set, contains black bars on the top and bottom; there are two types of widescreen: anamorphic, and non-anamorphic; for simplicity's sake, non-anamorphic is refered to as letterbox".Frankly that's just wrong though - widescreen is a term which refers only to the 1.85:1 ratio or with the addition of the word European, to the 1.66:1 ratio. 2.35:1 is called 'scope, and is not widescreen.
Frankly, you should explain that to studios, like Warner Brothers or Fox, who use the term "Widescreen" to describe DVD releases like Superman or Attack of the Clones which use aspect rations of 2.35:1!!
The former DOES mention the word "scope" in describing what widescreen means, though.
Frankly that's just wrong though - widescreen is a term which refers only to the 1.85:1 ratio or with the addition of the word European, to the 1.66:1 ratio. 2.35:1 is called 'scope, and is not widescreen.Sorry, but that doesn't accurately represent the historical (and, indeed, current) usage of the term. "Widescreen" is used for any AR wider than 1.33:1/1.37:1. Even Webster's Dictionary has it right.
DJ
Actually, as I was going to cite Fox and their usage of letterbox anyway, the 2006 Star Wars releases imply Fox has shifted their gears to the HTF usage, as the 2004 versions of the Star Wars films are listed as "Widescreen format enhanced for 16:9 TVs (Aspect Ratio 2.35:1)", whereas the original theatrical versions are listed as "4:3 Letterbox format (Aspect Ratio 2.35:1).
Like Star Wars, there will never be a definitive version of the definition of "letterbox."
No one wants to say "non-anamorphic" on the box because it's like saying "not-as-good". 4:3 letterbox is in a sense accurate since the DVD presents you a 4:3 image (as opposed to a 16:9 image), albeit a big chunk of that image is black bars. They can't really say "optimized for 4:3 TV's" either, since that could imply pan and scan.
wouldn't that just be referred to as 'flat'I always thought "flat" meant 1.85, "academy" meant 1.33/7, "scope" meant 2.35, and "letterbox" meant non-anamorphic. The confusing thing to me is that "anamorphic" means different things based on whether you're talking about lenses or DVDs. Everyone has their own meanings for these same words though. It's like sayng the word "formal" to a painter, writer, cinematographer, and dumbass- they'll all have totally different ideas of what you mean. I often simply use the word "wide" as slang for 2.35. People know what I mean. If I say "2.35 to 1," they'll look at me like I'm crazy.
Nathan
"Flat" just means that spherical lenses, as opposed to anamorphic lenses, were used in shooting. A film shot flat could be for intended projection at 1.37:1, 1.66:1, 1.85:1, or even 2.39:1 if using Super35.
"Academy" means 1.37:1.
"Scope" means anamorphic lenses were used during filming. The current SMPTE standard for scope projection is 2.39:1, but it has changed over there years. There have also been other systems that used 1.5x and 1.25x scope lenses (as opposed to the standard 2x) that gave different results entirely.
"Letterbox" is a term that predates "anamorphic" video by decades. Through repeated misusage, it has unfortunately acquired the connotation you describe.
DJ
