Go to www.projectorcentral.com and you can find alot of info on this model. Also check the www.avsforum.com and do a search and there is alot of talk about htis unit.
Greg
Since I don't think that InFocus makes a video grade projector, this is probably one of the conference room versions (and probably a portable at that).
I've borrowed my company's InFocus a couple of times before I got my RPTV and they worked fairly well.
The biggest problem with buying one is that these are not designed for a home theater so they exibit the following properties:
Loud cooling fan
Flaring whites
Stray light from the vents
Washed out blacks
I would not spend $2000 for one. The picture on any RPTV of the same price is going to kill compared that lousy picture from one of these projectors. If the price is $500, then maybe I would consider one for special occasions like "drive-in" night outside, or superbowl parties.
Brian
