InFocus IN76 Projector Problems (1 Viewer)
iKokomo
Grip
Carl Oak
My InFocus IN76 is having a problem. I have a video attached of the problem.
I click the button to turn it on and the fans spin up and also the color wheel spins up, but after 5-8 seconds the wheel turns off. Twenty seconds later the color wheel spins ups and turns off again.
After I placed the cover back on the projector, the light turns on, but it is very dim and it shows a clear screen, not a white projected screen, but clear, like a flashlight.
None of the buttons work after it turns on. I have to pull the plug from the wall in order to shut it off.
Does anyone know what the problem is? Thanks!
Aca
Aca
Hi, I have exactly the same problem. I know that this was long time ago but did you manage to solve this issue?
tgroskop
