Brian Herold
Grip
- Aug 31, 2004
Well, Im moving to a new apartment and I finally have the space for a decent sized TV - I play a lot of videogames, thus due to burn-in and brightness concerns I'm thinking either an LCD or DLP projection set is the way to go.
I'm on a fairly tight budget of about $1500, but I can probably slide this number around if necessary.
Ive sort of been looking at the following:
-Sony KP51WS520 51" CRT projection ~$1500
-Toshiba 46HM84 46" DLP projection ~$1400
-Sammy HLN467W/HLP4663W 46" DLP projection ~1500$ (though I did hear there were lag isues in videogames running in interlaced modes on the samsung dlp's)
I've read some of the master burn-in thread and I still dont know how worried I should be, so going crt over dlp scares me a bit, but if its not really the issue some make it out to be maybe im better off going with the sony. Either way, if you can recommend something better that ive overlooked, id really appriciate it - not sure if theres a favorite set floating around on here that I missed... Thx!
