Andres Munoz
- Dec 21, 1999
It's actually just one 6'x6' panel that I'm installing and while I've read up a bit on the internet, I'd like to get input from people that have actually done it. This is the one I'm eyeing.
As far as parts, I know I need the 6'x6' panel, the two end posts, post tops, rail brackets, screws, etc.
I believe I also need rebars? Do you put the post first and then the rebar inside?
Besides filling the hole with concrete, do I fill up the hollow post with concrete as well? Up to what height?
The instructions that I've read talk about rails like a separate piece but the panel that I want to buy seems to have the rails already installed to the panel. How was yours?
Any help will be deeply appreciated.
Thanks.
Thanks.
